  • 9 voto(s) - 3.78 Media
(22-07-2023, 11:44 AM)Velero Simbad escribió:  Una raya mato a un documentalista australiano que llevaba toda su vida filmandolas,  lo atravesó sin más y sin ningún hecho especial que hubiera ocurrido previamente, era una película más.
Recuerdo ese caso:
https://www.elmundo.es/cronica/2023/06/2...b45a6.html
Agradecido por: vecino
(22-07-2023, 01:20 PM)Hippie escribió:  https://www.elmundo.es/cronica/2023/06/2...b45a6.html
Hipótesis
Lo que dicen en Orca Atack Solutions:
ORCAS are now:
- Barbate. They seem to move in the hot areas described since March.
- Between Estepona and Malaga. 6 orcas. We do not know if they are moving the med, or staying in this area.
- SW of Brest, moving slowly to the NW (satellite tagged).
All Iberian orcas seem to interact now.
In all occasions they stay around 80 meters depth as mean, moving between 30 and 180 meters depth feeding on Bluefin tunas. The situation is the same as in spring, but expanded to other areas... it is not out of control.
They do not care about the type of boat, monohulls, colors, time of the day, or if it rains or not. They just look for environmental enrichment, anything to play with. They push at the bottom of the rudder and push until it breaks.
SOLUTIONS:
  • Avoid the orcas.
  • RUN RUN RUN, (at 4 knots the angle of attack of the orcas will be only 45º, cos (45º)=0,5, then the force they need to break the rudder is double thanif you stay stopped.
  • Do not stop. If you stop, the angle is 90º... the cos of (90º) is 1, therefore they have all the power to breake it.
  • RUN RUN RUN. After 5 minutes, at 5 knots, they should return where the tunas are.
  • Do not stop. If you stop, you stay more than 5 minutes with them,.
  • install the system on your rudder that repel them. Pigeon stuff is perfect. They work.
https://www.facebook.com/groups/orcasattackssolutions
Velero
Muy interesante.
Y además, parece que sí que estaban estudiando el tema:
Cita:Este investigador va a entregar a lo largo de esta semana un informe de conclusiones al Ministerio de Transición Ecológica sobre un estudio del comportamiento de las orcas que le encargó este departamento en julio del año pasado. El objetivo era tratar de comprender por qué actúan así y ver si es posible evitar los incidentes con las embarcaciones.
(24-07-2023, 08:35 AM)caribdis escribió:  Lo que dicen en Orca Atack Solutions:
ORCAS are now:
SOLUTIONS:
  • Avoid the orcas.
Velero
L a solucion primera mola !!
la ultima tambien es curiosa , sobre eso se deberia trabajar , he visto cosas horribles , lo de las palomas deberia bastar ???
y tambien he visto gente que promueve soltar una red lastrada por popa , como si fuera una cortina , para impedir que las orcas se acerquen por popa mientras sigues a mas de 5 nudos !!!
A qué se refiere con lo de las palomas. Se trataría de esos pequeños pinchos que se ponen en los relieves de los edificios? Si es eso, no sería muy fácil enganchar ahí todo lo que sea: algas, cabos, plásticos...?
(24-07-2023, 11:50 AM)hopetos escribió:  A qué se refiere con lo de las palomas. Se trataría de esos pequeños pinchos que se ponen en los relieves de los edificios? Si es eso,  no sería muy fácil enganchar ahí todo lo que sea: algas, cabos, plásticos...?
en esencia es eso , pero yo he visto imagenes de cinturones con pinchos de cerca de un palmo  y todo ese conjunto atornillado a la pala del timon. La cuestion seria cual es la minima densidad disuasiva de pinchos , como fijarlos etz etz...por asi decirlo es como el collar de pinchos de los mastines que les ponian contra   los lobos . Enganchar algo seguro , pero si disuade ?
imagen aqui ...y los he visto mucho mucho mas grandes, los pinchos
https://www.facebook.com/photo/?fbid=135...2800154594
https://www.facebook.com/photo/?fbid=101...2800154594
Ya lo puse hace poco, minuto 8
(24-07-2023, 04:09 PM)Velero Simbad escribió:  Ya lo puse hace poco, minuto 8
no se ....ese señor se curra el timon que tenia con osmosis y delaminado y va y le mete ahora un monton de tornillos ??? no lo veo !!! yo veo mas una tabla de faquir .... cuando intentas coger un cardo no tiene los pinchos gigantes, algo como lo de las palomas , pero un poco mas resistente
(24-07-2023, 04:29 PM)Noruego escribió:  no se ....ese señor se curra el timon que tenia con osmosis y delaminado y va y le mete ahora un monton de tornillos ??? no lo veo !!! yo veo mas una tabla de faquir .... cuando intentas coger un cardo no tiene los pinchos gigantes, algo como lo de las palomas , pero un poco mas resistente
No, si estos están como un cencerro, arofo en deseos de ver que pasa si tienen una "interactuación"  Sip
(24-07-2023, 11:03 PM)Velero Simbad escribió:  No, si estos están como un cencerro, arofo en deseos de ver que pasa si tienen una "interactuación"  Sip
Eso mismo pensé yo
(25-07-2023, 01:19 PM)gypsylyon escribió:  Eso mismo pensé yo
lo de cencerros ira con los Benlluire??
(25-07-2023, 03:49 PM)Noruego escribió:  lo de cencerros ira con los Benlluire??
Mi no comprender.
Pero mi timon es de kevlar.  Les va a costar incar el diente
(25-07-2023, 05:20 PM)gypsylyon escribió:  Mi no comprender.
estas espeso hehehe
esta pareja tienen un belliure  50.....y decimos que un estan un poco cencerros !
tu tienes un belliure  38?? igual eso de cencerros va junto con la propiedad de los belliure !!! es broma!
Último mensaje por Vilanova
03-10-2025, 06:48 PM
Último mensaje por Martin Iut
19-08-2023, 01:47 PM
